Rasim Öztürk
[YENI] : TREX 700 XN Dominator
Technical specifications:
Length: 1346mm
Height: 384mm
Width: 202mm
Main rotor blade length: 700mm
Main rotor diameter: 1570mm
Tail rotor blade length: 106mm
Tail rotor diameter: 281mm
Motor pinion: 13Z
Main gear: 107Z
Autorotation gear: 104Z
Tail rotor gearbox: 22Z
Translation: 8.23: 1: 4.73
Tank capacity: 630cc
Take-off weight (with battery): 4540g
Content:
1x Align T-REX 700XN Dominator
1 pair of 700mm carbon main rotor blades
1 pair of 106mm carbon tail rotor blades
3x Align DS820M swashplate servo
1x Align DS825M tail servo
1x Align DS530 throttle servo
1x Align B6TX 2-in-1 voltage regulator / pre-glow unit
1x BEASTX Governor Sensor
- ERC markette satışta...
Fiyat 1200 dolar
T-REX 700XN Dominator Super Combo
Features:
**New slim chassis design
**Revised clutch lining with steel alloy
**New powerful cooling system
**Reinforced carbon rear support
**New main and tail rotor blade design in yellow / black
**Includes the proven DS820M / DS825M High Voltage Brushless Servos plus DS530 Digital Gas Servo
Length: 1346mm
Height: 384mm
Width: 202mm
Motor pinion: 13Z
Main gear: 107Z
Content:
