Wireless Sim & Trainer - Futaba ve Hitec Kumandalar için
Koda soyle bir baktim dun aksam, ama hicbisey anlamadim. [emoji1] Bu aksam paylasirim, bir bakarsin.
Bugun bir boslukta 15dk.da pro miniyi aliciya baglayiverdim. Tam alici boyutunda oldugundan gayet guzel oldu :) Aksam onun da resmini yuklerim.
Kodla ilgili tek sorun zaman zaman thr kanali sacmalayabiliyor. Onu cozmem lazim, zira pitch de ayni kanala bagli simde, yere yapisiyor alet [emoji16]
Kod bu:
Kod:
//  8 Channel PWM to 1 channel PPM converter for RC receivers, using Arduino
//  THis firmware is based on ArduPPM Version v0.9.87 from
// http://code.google.com/p/ardupilot-mega/source/browse/Tools/ArduPPM/
// ..and has been hacked code to:
//   only support Atmel328 chips ( as found on Arduino Duemilanove or Arduino Uno )  chips
//   not support any "error" mode/s, just 8 PWM-IN  channels TO one single PPM OUT
//   not support any LED indicators m just PWM-IN, and PPM-OUT
//  Integrated the one library that is used to the sketch, for easy user experience.
//   made it Arduino IDE compatible, so it uses standard bootloader and Serial uploader, like all realy Arduino/s.
//  make compile-time option to either "hold last good PPM value" or "hold default value/s" in case of
//   no actual input signal for each channel.   see FAILHOLD and FAILCENTRE in .h file
// David/Buzz Sept 3rd 2012.
// PREPROCESSOR DIRECTIVES
#include "Arduino.h"
#include "ppm_encoder.h"
#include <util/delay.h>
#include <avr/io.h>
#define	ERROR_THRESHOLD		2									// Number of servo input errors before alerting
#define ERROR_DETECTION_WINDOW	3000 * LOOP_TIMER_10MS			// Detection window for error detection (default to 30s)
#define	ERROR_CONDITION_DELAY	500 * LOOP_TIMER_10MS			// Servo error condition LED delay (LED blinking duration)
#define PASSTHROUGH_MODE_ENABLED	// Comment this line to remove CH8 radio passthrough mode support (hardware failsafe for Arduplane)
#define PASSTHROUGH_CHANNEL		8 * 2	// Channel for passthrough mode selection
#define PASSTHROUGH_CHANNEL_OFF_US		ONE_US * 1600 - PPM_PRE_PULSE	// Passthrough off threshold
#define PASSTHROUGH_CHANNEL_ON_US		ONE_US * 1800 - PPM_PRE_PULSE	// Passthrough on threshold
#define THROTTLE_CHANNEL		3 * 2	// Throttle Channel
#define THROTTLE_CHANNEL_LED_TOGGLE_US		ONE_US * 1200 - PPM_PRE_PULSE	// Throttle Channel Led toggle threshold
#define LED_LOW_BLINKING_RATE	125 * LOOP_TIMER_10MS // Led blink rate for low throttle position (half period)
// Timers
#define TIMER0_10MS		156			// Timer0 ticks for 10 ms duration
#define TIMER1_10MS		20000		// Timer1 ticks for 10 ms duration
#define TIMER2_100MS		1562	// Timer2 ticks for 100 ms duration
#define LOOP_TIMER_10MS	10			// Loop timer ticks for 10 ms duration
// LED Code
#define	SPACE_SHORT_DURATION	40 * LOOP_TIMER_10MS	// Space after short symbol
#define	SPACE_LONG_DURATION	75 * LOOP_TIMER_10MS		// Space after long symbol
#define	SYMBOL_SHORT_DURATION	20 * LOOP_TIMER_10MS	// Short symbol duration
#define	SYMBOL_LONG_DURATION	100 * LOOP_TIMER_10MS	// Long symbol duration
#define	INTER_CODE_DURATION	150 * LOOP_TIMER_10MS		// Inter code duration
#define INTER_CODE		0		// Symbols value for coding
#define SHORT_SYMBOL	1
#define LONG_SYMBOL		2
#define SHORT_SPACE		3
#define LONG_SPACE		4
#define LOOP			5
// PPM ENCODER INIT AND AUXILIARY TASKS
	// LOCAL VARIABLES
	bool localinit = true; // We are inside init sequence
	bool mux_passthrough = false; // Mux passthrough mode status Flag : passthrough is off
	uint16_t led_acceleration; // Led acceleration based on throttle stick position
	bool servo_error_condition = false;	//	Servo signal error condition
	static uint16_t servo_error_detection_timer=0;		// Servo error detection timer
	static uint16_t servo_error_condition_timer=0; 		// Servo error condition timer
	static uint16_t blink_led_timer = 0; 		// Blink led timer
	#ifdef PASSTHROUGH_MODE_ENABLED
	static uint8_t mux_timer = 0;				// Mux timer
	static uint8_t mux_counter = 0;				// Mux counter
	static int8_t mux_check = 0;
	static uint16_t mux_ppm = 500;
	#endif
	static uint16_t led_code_timer = 0;	// Blink Code Timer
	static uint8_t led_code_symbol = 0;	// Blink Code current symbol
	// LOCAL FUNCTIONS
	// Led blinking (non blocking) function
	uint8_t blink_led ( uint16_t half_period )	// ( half_period max = 65 s )
		blink_led_timer++;
		if ( blink_led_timer < half_period ) // If half period has not been reached
			return 0; // Exit timer function and return 0
		else	// half period reached - LED Toggle
			PPM_PORT ^= ( 1 << PB0 );	// Toggle status LED
			blink_led_timer = 0;	// Blink led timer reset
			return 1;	// half period reached - Exit timer function and return 1
	// Led code (non blocking) function
	void blink_code_led ( uint8_t code )
		const uint8_t coding[2][14] = {
		// PPM_PASSTROUGH_MODE
		{ INTER_CODE, LONG_SYMBOL, LONG_SPACE, SHORT_SYMBOL, SHORT_SPACE, SHORT_SYMBOL, LOOP },
		// JETI_MODE
		{ INTER_CODE, LONG_SYMBOL, LONG_SPACE, SHORT_SYMBOL, SHORT_SPACE, SHORT_SYMBOL, SHORT_SPACE, SHORT_SYMBOL,LOOP }
		led_code_timer++;
			switch ( coding [ code - 2 ] [ led_code_symbol ] )
				case INTER_CODE:
				if ( led_code_timer < ( INTER_CODE_DURATION ) ) return;
				else PPM_PORT |= ( 1 << PB0 );		// Enable status LED
				break;
				case LONG_SYMBOL:	// Long symbol
				if ( led_code_timer < ( SYMBOL_LONG_DURATION ) ) return;
				else PPM_PORT &= ~( 1 << PB0 );	// Disable status LED
				break;
				case SHORT_SYMBOL:	// Short symbol
				if ( led_code_timer < ( SYMBOL_SHORT_DURATION ) ) return;
				break;
				case SHORT_SPACE:	// Short space
				if ( led_code_timer < ( SPACE_SHORT_DURATION ) ) return;
				break;
				case LONG_SPACE:	// Long space
				if ( led_code_timer < ( SPACE_LONG_DURATION ) ) return;
				break;
				case LOOP:	// Loop to code start
				return;
				break;
		led_code_timer = 0;	// Code led timer reset
		led_code_symbol++;	// Next symbol
		return; // LED code function return
	// ppm reading helper - interrupt safe and non blocking function
	uint16_t ppm_read( uint8_t channel )
		uint16_t ppm_tmp = ppm[ channel ];
		while( ppm_tmp != ppm[ channel ] ) ppm_tmp = ppm[ channel ];
		return ppm_tmp;
	// INITIALISATION CODE
void setup() {
	// Reset Source checkings
	if (MCUSR & 1)	// Power-on Reset
	   MCUSR=0; // Clear MCU Status register
	   // custom code here
	else if (MCUSR & 2)	// External Reset
	   // custom code here
	else if (MCUSR & 4)	// Brown-Out Reset
	   brownout_reset=true;
	else	// Watchdog Reset
	   // custom code here
	// Servo input and PPM generator init
	ppm_encoder_init();
	// Outputs init
	PPM_DDR |= ( 1 << PB0 );	// Set LED pin (PB0) to output
	PPM_DDR |= ( 1 << PB1 );	// Set MUX pin (PB1) to output
	PPM_DDR |= ( 1 << PPM_OUTPUT_PIN );	// Set PPM pin (PPM_OUTPUT_PIN, OC1B) to output
	// Timer0 init (normal mode) used for LED control and custom code
	TCCR0A = 0x00;	// Clock source: System Clock
	TCCR0B = 0x05;	// Set 1024x prescaler - Clock value: 15.625 kHz - 16 ms max time
	TCNT0 = 0x00;
	OCR0A = 0x00;		// OC0x outputs: Disconnected
	OCR0B = 0x00;
	TIMSK0 = 0x00;		// Timer 1 interrupt disable
	// Enable global interrupt
	sei();			// Enable Global interrupt flag
	// Disable radio passthrough (mux chip A/B control)
	PPM_PORT |= ( 1 << PB1 );	// Set PIN B1 to disable Radio passthrough (mux)
void loop() {
	// AUXILIARY TASKS
	PWM_LOOP: // SERVO_PWM_MODE
	while( 1 )
		_delay_us (950); // Slow down while loop
	}	// PWM Loop end
} // main lopo function end
Lib bu:
[noae]
Kod:
#ifndef _PPM_ENCODER_H_
#define _PPM_ENCODER_H_
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/wdt.h>
// SERVO INPUT FILTERS
// Using both filters is not recommended and may reduce servo input resolution
// #define _AVERAGE_FILTER_         // Average filter to smooth servo input capture jitter
// #define _JITTER_FILTER_             // Cut filter to remove 0,5us servo input capture jitter
#ifndef F_CPU
#define F_CPU               16000000UL
#endif
#ifndef true
#define true                1
#endif
#ifndef false
#define false               0
#endif
//#ifndef bool
//#define bool                boolean
//#endif
// 328 does not define PBX but defines an equivalent as PORTBX, comment these lines out if you already have a PB2 defined.
#define PB2 PORTB2
#define PB1 PORTB1
#define PB0 PORTB0
// SERVO INPUT MODE - !EXPERIMENTAL!
#define SERVO_PWM_MODE        1    // Normal 8 channel servo (pwm) input
// Servo input mode (jumper (default), pwm, ppm, jeti or spektrum)
volatile uint8_t servo_input_mode = SERVO_PWM_MODE;
// Number of Timer1 ticks in one microsecond
#define ONE_US                F_CPU / 8 / 1000 / 1000
// 400us PPM pre pulse
#define PPM_PRE_PULSE         ONE_US * 400
// SERVO LIMIT VALUES
// Servo minimum position
#define PPM_SERVO_MIN         ONE_US * 900 - PPM_PRE_PULSE
// Servo center position
#define PPM_SERVO_CENTER      ONE_US * 1500 - PPM_PRE_PULSE
// Servo maximum position
#define PPM_SERVO_MAX         ONE_US * 2100 - PPM_PRE_PULSE
// Throttle default at power on
#define PPM_THROTTLE_DEFAULT  ONE_US * 1100 - PPM_PRE_PULSE
// Throttle during failsafe
#define PPM_THROTTLE_FAILSAFE ONE_US * 900 - PPM_PRE_PULSE
// CH5 power on values (mode selection channel)
//#define PPM_CH5_MODE_4        ONE_US * 1555 - PPM_PRE_PULSE
// Number of servo input channels
#define SERVO_CHANNELS        8
// PPM period 18.5ms - 26.5ms (54hz - 37Hz)
#define PPM_PERIOD            ONE_US * ( 22500 - ( 8 * 1500 ) )
// Size of ppm[..] data array ( servo channels * 2 + 2)
#define PPM_ARRAY_MAX         18
// Data array for storing ppm (8 channels) pulse widths.
volatile uint16_t ppm[ PPM_ARRAY_MAX ] =
    PPM_PRE_PULSE,
    PPM_SERVO_CENTER,         // Channel 1
    PPM_PRE_PULSE,
    PPM_SERVO_CENTER,         // Channel 2
    PPM_PRE_PULSE,
    PPM_THROTTLE_DEFAULT,     // Channel 3 (throttle)
    PPM_PRE_PULSE,
    PPM_SERVO_CENTER,         // Channel 4
    PPM_PRE_PULSE,
    PPM_SERVO_CENTER,           // Channel 5
    PPM_PRE_PULSE,
    PPM_SERVO_CENTER,         // Channel 6
    PPM_PRE_PULSE,
    PPM_SERVO_CENTER,         // Channel 7
    PPM_PRE_PULSE,
    PPM_SERVO_CENTER,         // Channel 8
    PPM_PRE_PULSE,
    PPM_PERIOD
// SERVO FAILSAFE VALUES
const uint16_t failsafe_ppm[ PPM_ARRAY_MAX ] =
    PPM_PRE_PULSE,
    PPM_PRE_PULSE,
    PPM_PRE_PULSE,
    PPM_THROTTLE_FAILSAFE,    // Channel 3 (throttle)
    PPM_PRE_PULSE,
    PPM_PRE_PULSE,
    PPM_PRE_PULSE,
    PPM_PRE_PULSE,
    PPM_PRE_PULSE,
    PPM_PRE_PULSE,
    PPM_PERIOD
// AVR parameters for ArduPilot MEGA v1.4 PPM Encoder (ATmega328P)
#if defined (__AVR_ATmega328P__) || defined (__AVR_ATmega328__)
#define SERVO_DDR             DDRD
#define SERVO_PORT            PORTD
#define SERVO_INPUT           PIND
// PCIE2 PC Interrupt enable 2 is for Arduino Pins (D0-D7), also called PORTD.
#define SERVO_INT_VECTOR      PCINT2_vect
#define SERVO_INT_MASK        PCMSK2
#define SERVO_INT_CLEAR_FLAG  PCIF2
#define SERVO_INT_ENABLE      PCIE2
#define SERVO_TIMER_CNT       TCNT1
#define PPM_DDR               DDRB
#define PPM_PORT              PORTB
#define PPM_OUTPUT_PIN        PB2
#define PPM_INT_VECTOR        TIMER1_COMPB_vect
#define PPM_COMPARE           OCR1B
#define PPM_COMPARE_FLAG      COM1B0
#define PPM_COMPARE_ENABLE    OCIE1B
#else
#error NO SUPPORTED DEVICE FOUND! ( ATmega328/p)
#endif
// Used to indicate invalid SERVO input signals
//volatile uint8_t servo_input_errors = 0;
// Used to indicate missing SERVO input signals
volatile bool servo_input_missing = true;
// Used to indicate if PPM generator is active
volatile bool ppm_generator_active = false;
// Used to indicate a brownout restart
volatile bool brownout_reset = false;
// PPM GENERATOR START - TOGGLE ON COMPARE INTERRUPT ENABLE
// this starts OUTGOING PPM stream on PPM_PORT (PORTB, Arduino D8-D13)  at PPM_OUTPUT_PIN (PB2, arduino pin D10)
void ppm_start( void )
        // Prevent reenabling an already active PPM generator
        if( ppm_generator_active ) return;
        // Store interrupt status and register flags
        uint8_t SREG_tmp = SREG;
        // Stop interrupts
        cli();
        // Make sure initial output state is low
        PPM_PORT &= ~(1 << PPM_OUTPUT_PIN);
        // Wait for output pin to settle
        //_delay_us( 1 );
        // Set initial compare toggle to maximum (32ms) to give other parts of the system time to start
        SERVO_TIMER_CNT = 0;
        PPM_COMPARE = 0xFFFF;
        // Set toggle on compare output
        TCCR1A = (1 << PPM_COMPARE_FLAG);
        // Set TIMER1 8x prescaler
        TCCR1B = ( 1 << CS11 );
        // Enable output compare interrupt
        TIMSK1 |= (1 << PPM_COMPARE_ENABLE);
        // Indicate that PPM generator is active
        ppm_generator_active = true;
        // Restore interrupt status and register flags
        SREG = SREG_tmp;
// PPM GENERATOR STOP - TOGGLE ON COMPARE INTERRUPT DISABLE
void ppm_stop( void )
        // Stop interrupts
        cli();
        // Disable output compare interrupt
        TIMSK1 &= ~(1 << PPM_COMPARE_ENABLE);
        // Reset TIMER1 registers
        TCCR1A = 0;
        TCCR1B = 0;
        // Indicate that PPM generator is not active
        SREG = SREG_tmp;
// Watchdog Interrupt (interrupt only mode, no reset)
ISR( WDT_vect ) // If watchdog is triggered then enable missing signal flag and copy power on or failsafe positions
    // Use failsafe values if PPM generator is active or if chip has been reset from a brown-out
    if ( ppm_generator_active || brownout_reset )
        // Copy failsafe values to ppm[..]
        for ( uint8_t i = 0; i < PPM_ARRAY_MAX; i++ )
            ppm[ i ] = failsafe_ppm[ i ];
    // Set missing receiver signal flag
    // Reset servo input error flag
    //servo_input_errors = 0;
// SERVO/PPM INPUT - PIN CHANGE INTERRUPT, for any Arduino pin D0 -> D7
ISR( SERVO_INT_VECTOR )
    // Servo pulse start timing
    static uint16_t servo_start[ SERVO_CHANNELS ] = { 0, 0, 0, 0, 0, 0, 0, 0 };
	// Missing throttle signal failsafe
	static uint8_t throttle_timeout = 0;
	// Servo input pin storage
    static uint8_t servo_pins_old = 0;
    // Used to store current servo input pins
    uint8_t servo_pins;
    // Read current servo pulse change time
    uint16_t servo_time = SERVO_TIMER_CNT;
    // SERVO PWM MODE
CHECK_PINS_START: // Start of servo input check
    // Store current servo input pins
    servo_pins = SERVO_INPUT;
    // Calculate servo input pin change mask
    uint8_t servo_change = servo_pins ^ servo_pins_old;
    // Set initial servo pin and channel
    uint8_t servo_pin = 1;
    uint8_t servo_channel = 0;
CHECK_PINS_LOOP: // Input servo pin check loop
    // Check for pin change on current servo channel
    if( servo_change & servo_pin )
     // if (( servo_pin == 1  )  && (  ppm_generator_active = false) ) ppm_start();
     // if (( servo_pin == 8  )  && (  ppm_generator_active = true) ) ppm_stop();
        // High (raising edge)
        if( servo_pins & servo_pin )
            servo_start[ servo_channel ] = servo_time;
        else
            // Get servo pulse width
            uint16_t servo_width = servo_time - servo_start[ servo_channel ] - PPM_PRE_PULSE;
            // Calculate servo channel position in ppm[..]
            uint8_t _ppm_channel = ( servo_channel << 1 ) + 1;
           // Check that servo pulse signal is valid before sending to ppm encoder
            if( servo_width > PPM_SERVO_MAX ) goto CHECK_PINS_ERROR;
            if( servo_width < PPM_SERVO_MIN ) goto CHECK_PINS_ERROR;
            goto CHECK_PINS_NOERROR;
            CHECK_PINS_ERROR:
                // on width input error, use defailt/failsave value, OR previous value
               // choose the error handling type here!
                #define FAILHOLD 1
                #ifdef FAILCENTRE
                servo_width = failsafe_ppm[ _ppm_channel ]; // failsafe defaults, most channels centred, throttle lowered.
                #endif
                #ifdef FAILHOLD
                servo_width = ppm[ _ppm_channel ]; // all channels hold their previous position!
                #endif
             CHECK_PINS_NOERROR:
	    //Reset throttle failsafe timeout
	    if( _ppm_channel == 5 ) throttle_timeout = 0;
        #ifdef _AVERAGE_FILTER_
            // Average filter to smooth input jitter
            servo_width += ppm[ _ppm_channel ];
            servo_width >>= 1;
        #endif
        #ifdef _JITTER_FILTER_
            // 0.5us cut filter to remove input jitter
            int16_t ppm_tmp = ppm[ _ppm_channel ] - servo_width;
            if( ppm_tmp == 1 ) goto CHECK_PINS_NEXT;
            if( ppm_tmp == -1 ) goto CHECK_PINS_NEXT;
        #endif
            // Update ppm[..]
            ppm[ _ppm_channel ] = servo_width;
CHECK_PINS_NEXT:
    // Select next servo pin
    servo_pin <<= 1;
    // Select next servo channel
    servo_channel++;
    // Check channel and process if needed
    if( servo_channel < SERVO_CHANNELS ) goto CHECK_PINS_LOOP;
    goto CHECK_PINS_DONE;
    // All servo input pins has now been processed
CHECK_PINS_DONE:
    // Reset Watchdog Timer
    wdt_reset();
    // Set servo input missing flag false to indicate that we have received servo input signals
    servo_input_missing = false;
    // Store current servo input pins for next check
    servo_pins_old = servo_pins;
    // Start PPM generator if not already running
    if( ppm_generator_active == false ) ppm_start();
	// Throttle failsafe
	if( throttle_timeout++ >= 128 )
		// Reset throttle timeout
		// Set throttle failsafe value
		ppm[ 5 ] = PPM_THROTTLE_FAILSAFE;
    //Has servo input changed while processing pins, if so we need to re-check pins
    if( servo_pins != SERVO_INPUT ) goto CHECK_PINS_START;
    // Clear interrupt event from already processed pin changes
    PCIFR |= (1 << SERVO_INT_CLEAR_FLAG);
// PPM OUTPUT - TIMER1 COMPARE INTERRUPT
ISR( PPM_INT_VECTOR )
    // Current active ppm channel
    static uint8_t ppm_channel = PPM_ARRAY_MAX - 1;
    // Update timing for next compare toggle
    PPM_COMPARE += ppm[ ppm_channel ];
    // Select the next ppm channel
    if( ++ppm_channel >= PPM_ARRAY_MAX )
		ppm_channel = 0;
// PPM READ - INTERRUPT SAFE PPM SERVO CHANNEL READ
/* uint16_t ppm_read_channel( uint8_t channel )
    // Limit channel to valid value
    uint8_t _channel = channel;
    if( _channel == 0 ) _channel = 1;
    if( _channel > SERVO_CHANNELS ) _channel = SERVO_CHANNELS;
    // Calculate ppm[..] position
    uint8_t ppm_index = ( _channel << 1 ) + 1;
    // Read ppm[..] in a non blocking interrupt safe manner
    uint16_t ppm_tmp = ppm[ ppm_index ];
    while( ppm_tmp != ppm[ ppm_index ] ) ppm_tmp = ppm[ ppm_index ];
    // Return as normal servo value
    return ppm_tmp + PPM_PRE_PULSE;
// PPM ENCODER INIT
void ppm_encoder_init( void )
    // SERVO/PPM INPUT PINS
    // Set all servo input pins to inputs
    SERVO_DDR = 0;
    // Activate pullups on all input pins
    SERVO_PORT |= 0xFF;
    if( servo_input_mode == SERVO_PWM_MODE )
        // Set servo input interrupt pin mask to all 8 servo input channels
        SERVO_INT_MASK = 0xFF;
    // Enable servo input interrupt
    PCICR |= (1 << SERVO_INT_ENABLE);
    // PPM OUTPUT PIN
    // Set PPM pin to output
    PPM_DDR |= (1 << PPM_OUTPUT_PIN);
    // Enable watchdog interrupt mode
    // Disable watchdog
    wdt_disable();
     // Reset watchdog timer
    wdt_reset();
     // Start timed watchdog setup sequence
    WDTCSR |= (1<<WDCE) | (1<<WDE );
    // Set 250 ms watchdog timeout and enable interrupt
    WDTCSR = (1<<WDIE) | (1<<WDP2);
#endif // _PPM_ENCODER_H_
[/noae]
