[Urun]: Synergy E5 İnceleme
E5 değil belki ama;
Synergy E6/E7 Kit Torque Tube FBL Kit
Midlandde indirmde.... Hem de ciddi indirim... 333.32£.... Yaklaşık 1540 lira yapıyor... O paraya bildiğiniz gibi goblin570 bile geliyor gelmiyor arası...
LINK;
Now featuring unparalleled Mod 1.25 Tail Transmission -
Mod 1.25 machined Delrin bevel and spur gears are super silent while providing high durability for today’s 3D pilot.
Precision Machined Helical Main Gear-
Smooth running Mod 1 custom machined helical gear is stealthy silent and provides plenty of girth for today’s high powered electric motors. Settling for a molded main gear on a high powered electric was just not an option.
Third Bearing Block Main Shaft Support-
The main shaft has third bearing block support to ensure proper gear mesh and eliminate frame flexing during hard 3D maneuvers.
Motor Shaft Pinion Support-
The E6 pinion is supported by a lower bearing block which also ensures a proper gear mesh.
Carbon Servo Arms-
Custom carbon servo arms for the ultimate precision in flight.
Features:
Precision machined helical main gear
Third bearing block support for main shaft
Bearing block support for motor pinion
Multiple battery configuration options (8s, 10s, 12s)
Flybarless head designed specially for ALL of today’s FBL Electronics
Extremely light and Ultra rigid carbon fiber frame design for those serious competition pilots
Motor mount handles M4x30mm mounting patterns
Motors up to 60mm in diameter accepted between frames
Accepts rotor blades 600-716
Carbon servo arms provide for a much better precision feel in flight
14 and 15 tooth pinions included!
Unparalleled Mod 1.25 Shaft Driven Tail Transmission
