Mustafa ÇOBAN
- Katılım
- 28 Eki 2014
- Mesajlar
- 2,604
- Tepkime puanı
- 2,209
- Web sitesi
- www.kervansaraykahve.com.tr
- İlgi Alanı
- Heli
Hayır 1.2.0 versiyon firmware çıkarmışlar onunla ücretsiz güncelliyor.
Edit: birde stabilizayon acro gelmiş. ve hepsi
1-Governor support - Built-in governor with support for Electric, Nitro and Gasser helicopters!
2-Brand new Stabilisation - Significantly improved stabilisation mode with new possibilities.
3-30 minute Logs - From now the unit can store 3 times longer flight events.
4-Spektrum SRXL - New protocol support in SRXL family.
5-Improved JETI model integration - Integration with Duplex is even smoother now.
6-Better calibration procedure - Calibration procedure can handle slower voltage rampup with various receivers now.
7-Sensor data processing - The way data are comming from the sensor is even faster.
8-Event capturing - Improved event capturing in the flight log.
9-Normal (Rate) mode - To fulfill needs of the scale pilots Normal gyro mode was updated.
10-Software updates - Various fixes and improvements were introduced in the software.
11-Flash procedure - Flashing process has double verification to make it even more reliable.
12-Spektrum Failsafe - Failsafe for the Spektrum satellites supports all available channels now.
13-Factory Settings - Factory settings were modified to make the tuning process even shorter.
