Spirit Firmware Yeni Sürümü : V 2.4.2
Henüz haberi olmayan arkadaşlar için bilgilendirme olsun %p
Özetle MAJOR bir değişiklik veya yenilikler yok. Küçük bazı ilaveler ve düzeltmeler yapılmış ;)
Download için :
Version 2.4.2 was released!
  • Graupner HoTT integration:
    • Added new Telemetry variable - Throttle PWM [ms] - reported under Climb rate.
  • OpenTX integration:
    • New diagnostic script for displaying channel values - script diagnostic.lua.
    • Full support for the Log Viewer - script logviewer.lua.
    • Added configuration for the ESC Telemetry.
    • Added new Telemetry variable - Throttle PWM [µs]
  • Jeti integration:
    • RPM readout can't overflow - the max. value is 8191.
  • ESC Telemetry:
    • Castle Creations:
      • Telemetry readout is stable also when Spirit Governor is enabled.
      • Fixed capacity calculation when Spirit Governor is enabled.
    • Kontronik Kosmik & Jive Pro:
      • RPM: readout is compatible with all configurations now.
    • HobbyWing Platinum V4:
      • HobbyWing v4 120A: temperature calculation was corrected.
    • NOTE: All telemetry guides are available at the .
  • Manual:
    • New Chinese traslation was added! (Big Thanks to Mr. Wong)
    • Pin layout for Spirit and µSpirit units is .
  • Spirit Settings:
    • Real-Time tuning:
      • When special function is assigned but channel is unassigned, the function will be automatically unassigned when window is closed.
    • Translation:
    • Setup Wizard:
      • Updated profiles for T-Rex 150, T-Rex 250, Blade 130S, Blade 230S, Oxy 2 and Oxy 3.
    • News noticement:
      • Automatic noticement of a new available updates.
      You do not have to change any settings after the update from the previous version 2.3 and 2.4.x.
Teşekkürler abi
SM-A710F cihazımdan Tapatalk kullanılarak gönderildi
