Quadcopter vibrasyon (Titreme)
sayın hocam "get status" yazınca aşağıdaki gibi yazı gelmektetir.
CLI
# get status
Invalid name
set (ayarlarım) listedeki gibidir
$M>†tARM;AIR MODE;ANTI GRAVITY;ANGLE;HORIZON;HEADFREE;BARO;MAG;HEADADJ;FAILSAFE;BEEPER;BLACKBOX;BLACKBOX ERASE (>30s);FPV ANGLE MIX;OSD SW;ª$M>–í~$M>ni
CLI
# get acc
align_acc = DEFAULT
Allowed values: DEFAULT, CW0, CW90, CW180, CW270, CW0FLIP, CW90FLIP, CW180FLIP, CW270FLIP
acc_hardware = AUTO
Allowed values: AUTO, NONE, ADXL345, MPU6050, MMA8452, BMA280, LSM303DLHC, MPU6000, MPU6500, MPU9250, ICM20601, ICM20602, ICM20608, ICM20689, BMI160, FAKE
acc_lpf_hz = 10
Allowed range: 0 - 400
acc_trim_pitch = 0
Allowed range: -300 - 300
acc_trim_roll = 0
accxy_deadband = 40
Allowed range: 0 - 100
accz_deadband = 40
acc_unarmedcal = ON
Allowed values: OFF, ON
yaw_accel_limit = 100
Allowed range: 1 - 500
accel_limit = 0
# set
Current settings:
align_gyro = DEFAULT
gyro_lpf = 42HZ
gyro_sync_denom = 3
gyro_lowpass_type = PT1
gyro_lowpass = 90
gyro_notch1_hz = 400
gyro_notch1_cutoff = 300
gyro_notch2_hz = 200
gyro_notch2_cutoff = 100
moron_threshold = 48
gyro_use_32khz = OFF
gyro_isr_update = OFF
align_acc = DEFAULT
acc_hardware = AUTO
acc_lpf_hz = 10
acc_trim_pitch = 0
acc_trim_roll = 0
align_mag = DEFAULT
mag_hardware = AUTO
mag_declination = 0
magzero_x = 65500
magzero_y = 64775
magzero_z = 65032
baro_hardware = AUTO
baro_tab_size = 21
baro_noise_lpf = 600
baro_cf_vel = 985
baro_cf_alt = 965
mid_rc = 1500
min_check = 1100
max_check = 1900
rssi_channel = 0
rssi_scale = 30
rssi_invert = OFF
rc_interp = AUTO
rc_interp_ch = RP
rc_interp_int = 19
fpv_mix_degrees = 0
max_aux_channels = 6
serialrx_provider = SPEK1024
sbus_inversion = ON
spektrum_sat_bind = 0
spektrum_sat_bind_autoreset = 1
airmode_start_throttle = 1350
rx_min_usec = 885
rx_max_usec = 2115
input_filtering_mode = OFF
blackbox_rate_num = 1
blackbox_rate_denom = 1
blackbox_device = SPIFLASH
blackbox_on_motor_test = OFF
min_throttle = 1070
max_throttle = 2000
min_command = 1000
use_unsynced_pwm = ON
motor_pwm_protocol = ONESHOT125
motor_pwm_rate = 480
motor_pwm_inversion = OFF
thr_corr_value = 0
thr_corr_angle = 800
failsafe_delay = 10
failsafe_off_delay = 10
failsafe_throttle = 1000
failsafe_kill_switch = OFF
failsafe_throttle_low_delay = 100
failsafe_procedure = DROP
align_board_roll = 0
align_board_pitch = 0
align_board_yaw = 0
gimbal_mode = NORMAL
bat_capacity = 0
vbat_max_cell_voltage = 43
vbat_min_cell_voltage = 33
vbat_warning_cell_voltage = 35
vbat_hysteresis = 1
current_meter = NONE
battery_meter = ADC
bat_detect_thresh = 55
use_vbat_alerts = ON
use_cbat_alerts = OFF
cbat_alert_percent = 10
vbat_scale = 110
ibata_scale = 400
ibata_offset = 0
beeper_inversion = ON
beeper_od = OFF
beeper_frequency = 0
yaw_motors_reversed = OFF
3d_deadband_low = 1406
3d_deadband_high = 1514
3d_neutral = 1460
3d_deadband_throttle = 50
servo_center_pulse = 1500
servo_pwm_rate = 50
servo_lowpass_hz = 0
tri_unarmed_servo = ON
channel_forwarding_start = 4
rc_rate = 100
rc_rate_yaw = 100
rc_expo = 0
rc_yaw_expo = 0
thr_mid = 50
thr_expo = 0
roll_srate = 70
pitch_srate = 70
yaw_srate = 70
tpa_rate = 10
tpa_breakpoint = 1650
reboot_character = 82
serial_update_rate_hz = 100
accxy_deadband = 40
accz_deadband = 40
acc_unarmedcal = ON
imu_dcm_kp = 2500
imu_dcm_ki = 0
small_angle = 25
auto_disarm_delay = 5
disarm_kill_switch = ON
gyro_cal_on_first_arm = OFF
fixedwing_althold_reversed = OFF
alt_hold_deadband = 40
alt_hold_fast_change = ON
deadband = 0
yaw_deadband = 0
yaw_control_reversed = OFF
pid_process_denom = 1
d_lowpass_type = BIQUAD
d_lowpass = 42
d_notch_hz = 260
d_notch_cut = 160
vbat_pid_gain = OFF
pid_at_min_throttle = ON
anti_gravity_thresh = 350
anti_gravity_gain = 1000
setpoint_relax_ratio = 100
d_setpoint_weight = 60
accel_limit = 0
iterm_windup = 50
yaw_lowpass = 0
pidsum_limit = 500
pidsum_limit_yaw = 400
p_pitch = 58
i_pitch = 50
d_pitch = 35
p_roll = 44
i_roll = 40
d_roll = 30
p_yaw = 70
i_yaw = 45
d_yaw = 20
p_alt = 50
i_alt = 0
d_alt = 0
p_level = 50
i_level = 50
d_level = 100
p_vel = 55
i_vel = 55
d_vel = 75
level_sensitivity = 55
level_limit = 55
tlm_switch = OFF
tlm_inversion = OFF
tlm_halfduplex = ON
frsky_default_lat = 0
frsky_default_long = 0
frsky_gps_format = 0
frsky_unit = IMPERIAL
frsky_vfas_precision = 0
frsky_vfas_cell_voltage = OFF
hott_alarm_int = 5
pid_in_tlm = OFF
ibus_report_cell_voltage = OFF
ledstrip_visual_beeper = OFF
task_statistics = ON
debug_mode = NONE
