EZNOV Neuron flybarless
Evet arkadaşlar beklenen ünite çıkmış hem de oldukça güzel bir fiyata... Fastlad'de ilk parti için 79,16£ yanii 118,18$...
Sonraki fiyatı 150 dolar olacak. Başlangıç için rescue özellikli bir üniteye 120 dolar iyi fiyat. Aslında ünite almasaydım iki gün önce, denemek isterdim. En azından protos üzerinde...
Bu aralar hobisel açıdan tam bir krizdeyim, saniyeler içinde 5-6bin uçup gidince güzel olmuyor. Deneyecek arkadaşlar için şimdiden hayırlı olsun.
EZNOV Neuron Flight Stabiliser / Flybarless Unit
Welcome to the Ultimate Stabilisation System for helicopters, multi-rotors and planes.
Designed for all pilots to improve flight enjoyment and machine performance.
One of the big challenges for the new NEURON was to transform the complexity into the simple, and we succeeded. Electronics architecture and algorithms have been fully designed and developed by our engineers in our office in France. NEURON guarantees you the best stabilization system for each platform types. In fact, no rival offers more performance and feel.
NEURON ensure all pilots an ultra-smooth flight feeling, it brings you the awesome sentiment of being directly connected to your machine. Fast and secure, NEURON is the best choice to stabilize your helicopters, multi-rotors and planes.
The three specifics softwares are provided. Change the firmware as many times as you want and use your NEURON on all your RC models.
NEURON allows all pilots to obtain the best from their machines safely. Enjoy the unique NEURON’s flights experience.
Features
- Latest generation, 9 axis sensor (MPU-9250)
- Latest generation STM32F4 micro-controller with floating point unit
- Rock solid power stage (no more sat locks) up to 8.4V
- Very small: 23.15 x 34.5 x 13.6 mm
- Ultra light: 6.7g
- External USB connector for more installation flexibility
- Every connector is electrically protected
- Built-in RPM governor
- One built-in sat connector with smart bind
- Connect a second sat via an adapter
- Handles all serial output receivers (HoTT, SRXL, SBUS/SBUS2, JR XBus Mode B and Mode A, PWM sum, plus DSM2 and DSMX sats)
- Receiver auto-configuration
- RPM governor auto-configuration
- Set-up and tuning as simple as possible
- Rescue mode for helis, with pitch management
- Self-level mode for multi-rotors and planes
- Possibility to connect a Bluetooth module on USB adapter
- Files between PC and Android are compatibles
Included
- Free set-up terminal on PC (USB and Bluetooth)
- Free Android app (Bluetooth)
- Firmwares provided for all size helicopters, quads and planes
- Accessory cable and USB adapter provided
- Free updates
- 3 bottom case colours provided (time limited offer)
- 3M very high bond, double sided pad
