130 X Almayı Düşünüyorum
Rasim , filonun son kuşu da gerçekten çok güzel , hayırlı uğurlu olsun. :saygilar:
Sabit 130x konusu bulamadım burdan paylaşayım dedim. Default değerler uygun deniliyor ama yine de farklı gain değerleri ile uçmak isteyenler için şöyle bir setup var;
Blade 130x Optional Gyro Gain Menu
To enter Programming Mode:
1. Move the throttle stick to the full throttle (100% throttle travel) postion and power on the transmitter.
2. Connect the flight battery to the helicopter control unit.
3. The Status LED turns solid blue, then blinks in a series of Red, Green and Blue LEDs.
4. When the control unit is in programming mode, the Red LED is solid and the Status LED blinks.
Move the Elevator stick forward or backward to change between axes.
Red LED = Elevator
Green LED = Aileron
Blue LED = Rudder
Move the Aileron stick left or right to change the gain value.
The Axis LED Is solid when the gain is at the default (neutral) value.
Right Aileron increases the gain and the LEDs blinks faster.
Left Aileron decreases the gain and the LEDs blink slower.
There are ten steps available in each direction for a total of 20 gain values for each axis.
The highest and lowest values are within a predetermined range and do not prevent the helicopter from being flyable.
To reset the gain values to the default settings:
1. Adjust the Rudder travel value to 100% in both directions.
2. Hold right rudder for 5 seconds while in programming mode. The Red, Green and Blue LEDs will blink in a sequence
to indicate the default settings are active.
To exit the menu:
1. Disconnect the flight battery from the control unit.
2. Move the throttle stick to the low/idle position or activate Throttle Hold. Leave the transmitter powered on.
3. Connect the flight battery to the control unit.
