[Urun]: GOBLIN 380 SARI VE KIRMIZI, ÇİFTE KUTU AÇILIMI. VE MAİDEN
Evet arkadaşlar, benim için heli kurulumunun en sıkıcı olan lehim kısmını ilk başta hallettim.
Yarın da ufaktan kuruluma başlıcam.
BİLİYOSUNUZŞU AN DA GOBLİN 380 DE Lİ PO SEÇENEĞİ NE YAZIKKİ FAZLA YOK. ASLINDA VİDEOLARDA PULSE 1800MAH 65 C KULLANILIYOR AMA DAHA SATIŞA SUNULMADI. BENİM DE YAPTIĞIM KISA BİR ARAŞTIRMA SONUCU. PULSE EN YAKIN PİL THUNDER POWER PIİ BULDUM. 2700 MAH 70 C OLMASINA RAĞMEN PULSE 1800 İLE 90 GRAM FARK VAR. BU ARADA Kİ FARKI DA HELİYE Bİ KAÇ AZ EKİPMAN TAKARAK 40-50 GRAMA İNDİRMEYE ÇALIŞICAM. PULSE 2600 MAH ADA BAKTIM AMA O 2600 MAH 45C OLMASINA RAĞMEN AŞIRI AĞIRDI. AMA THUNDER POWER BU KONUDA BANA GÖZ KIRPTI. BAKALIM UÇUCAZ GÖRÜCEZ.
PULSE 1800 MAH 45C PİL.
Specifications:
Cell Count: 6S
Capacity: 1800mah
Discharge Rate: 45C
Charge Rate: 5C
Dimensions: 107mm x 33mm x 41mm (LxWxH)
Weight: 320 Grams
Balance Tap: JST-XH
Specifications:
Voltage: 22.2V
Cell Count: 6S
Capacity: 2600mAh
Discharge Rate: 45C
Charge Rate: 5C
Dimensions: 120mm x 33mm x 38mm (LxWxH)
Weight: 453g
Balance Tap: JST-XH
THUNDER POWER 2700 70C
Specification
Max Charge.................................12C
Max Cont. Discharge.....................70C
Max Burst Discharge.....................140C
Max Charge Current......................32.4A
Max Cont. Current........................189A
Max Burst Current........................378A
Weight (grams)............................409
Dimensions H x W x L (mm)........39 x 39 x 128
