[Satılık]: Turnigy 3XS FHSS 2.4GHz 3 Kanal Araba veya Tekne Kumandası
  • Konbuyu başlatan mavikaya2011
  • Başlangıç tarihi
  • 1,194
Durum
M
mavikaya2011
Guest
SATILMIŞTIR
Turnigy 3XS FHSS 2.4GHz 3 Kanal Araba veya Bot Kumandası
Sıfır gibi desem yeridir. 3-4 defa slash aracımda kullanılmıştır. Rc araba hobimi bıraktığım için satıyorum. Hatta benim yüklediğimm fotoğraflardan göreceğiniz gibi üzerindeki poşetleri bile daha çıkarmadım. İlk çıkaran siz olun. Bana maliyetinin bile nerdeyse altına veriyorum. Alan kişi hayrını görsün.
The Turnigy 3XS features a large, easy to read back-lit LCD, a quick access jog wheel for function selection and programming, 15 model memory, steering wheel extension as standard and a host of programming features normally only found on expensive "high-end" radios.
The 3XS not only looks great, it feels great in your hands, which is what really counts when it comes to surface radios. The ergonomics have been very well thought out on this one making all the functions such as Steering/Throttle trims easily accessible while operating your model. No need to take your hands off of the wheel or throttle trigger to make adjustments on the go!
This radio system is compatible with and includes the HK3100 3CH FHSS receiver. This receiver is compact and lightweight allowing you to install it in just about any model's radio compartment.
Features:
• EPA adjustment
• Sub trim
• Dual rates
• Servo reversing
• Programmable steering curve
• Programmable throttle curve
• ABS (anti-lock braking)
• 15 model memory
• Programmable steering/throttle speed
• Throttle hold function
• Integrated timer
Specs:
Transmitter;
Channels: 3
RF Type: 2.4GHz FHSS
Weight: 350g (without batteries)
Power: 4 x AA batteries
Receiver;
Channels: 3
Operating Voltage: 4.5~5.5V <30mA
Dimensions: 33 x 19 x 12mm
Weight: 9g
Required:
4 x AA battery
100 tl
Satılmıştır
Alana da satana da hayırlı olsun, konu KILIT ve ARSIV taşındı
Durum
