QUANTUM 4530-500 700 SINIFI HELİKOPTER MOTORU.
ARKADAŞLAR ELİMDE FAZLALIKTIR. HİÇ BİR SIKINTISI YOKTUR. AYRİYETTEN ELİMDE KISA ŞAFTI DA MEVCUTTUR.
ALAN ARKADAŞIN İÇİ RAHAT OLSUN MOTORA HER DURUMDA KEFİLİM.
Stator Diameter: 45mm
Stator Thickness: 30mm
No. of Magnet Poles: 10
No. of Stator Arms: 12
kV: 500 rpm/volt
No Load Current: 2.0 A @ 10V
Motor Resistance: 0.010 ohms
Max Continuous Current: 125 Amps
Max Continuous Power: 5000 Watts
Weight: 556 Grams
FİYAT: 425 TL
kV: 500 rpm/volt
Weight: 556 Grams
FİYAT: 425 TL
