Sıfır
HOBBYKING YEP 120A HV (4~14S) BRUSHLESS SPEED CONTROLLER (OPTO)
Trex 550 den Trex 800 e
Goblin 500 den goblin 770 e kadar.
Çok geniş yelpazede kullanabileceğiniz. Alman yge nin bire bir kopyası olan, . Active free-wheeling özelliği sayesinde düşük kafa turunda uçma imkanı sunan eşsiz bir esc dir
Kendim için almıştım. Ama ben aynısını yurt içinden 2. El tedarik ettim. Aciliyetim olduğu için.
Bu gelen de fazlalık oldu.
Fiyat: 410 TL dir.
Genel özellikleri.
Features:
� HV capability for use with up to 14S (51.8V) Lipoly
� Optional programming card for convenient setup
� ESC had separate programming lead built-in so there is no need to unplug from RX
� Super fine throttle resolution provides first-rate and highly accurate linearity
� Super smooth adjustable start-up mode
� Constant RPM mode (governor mode)
� Adjustable F3A brake.
� 3 steps adjustable normal EMF brake
� High anti-interference capability
� Low voltage cut-off protection with automatic adjustment for NiCd/NiMH/Li-Ion/LiPo/LiFePO4
� Soft cut-off option at low voltage, slows motor RPM gradual rather than hard cutoff (LVC)
� Low voltage cut-off can be disabled
� Variable cut-off voltage / cell
� Active free-wheeling circuit allows for unlimited "partial load" capability
� LED status display
� Adjustable motor timing from 0° to 30°
� Blocked rotation protection (senses a jammed motor and stops motor rotation)
� Over-temperature protection and overload alarm
� Anti sparking circuit: reduces connection sparks
� Throttle signal lose protection. If the signal is lost for 3 seconds, the power will automatically cut-off.
� Safe power-on. (Motor will not start until throttle is returned to lowest position)
***This ESC is compatible with both helicopter and airplane models.***
Specification:
Max Cont Current: 120A
Max Burst Current: 140A for 10 seconds
Input Voltage: 4-14 cells li-XX or 12-42 Ni-MH/Ni-Cd battery
BEC: None (OPTO)
PWM: 8~16 KHz
Max RPM: 240,000rpm for 2 Poles Brushless Motor
PCB Size: 68x53mm
Weight: 164g (including wires)
SM-G900H cihazımdan Tapatalk kullanılarak gönderildi
Fiyat: 410 TL dir.
Genel özellikleri.
Features:
Specification:
BEC: None (OPTO)
PWM: 8~16 KHz
PCB Size: 68x53mm
