- Katılım
- 29 May 2014
- Mesajlar
- 1,494
- Tepkime puanı
- 2,511
- Yaş
- 48
- Konum
- Adana
- Web sitesi
- www.drilkersonmez.com
- İlgi Alanı
- Heli
Goblin 500 Sport , Motor + ESC+ Servolar
Modeli ikinci modelim olarak kullanıyorum. Ederini veren olursa satılıktır. Kit sıfır ayarındadır. Toplam uçuş sayısı 4 dür.
Motor : Rotorstar 4956-1100kv
Turns: 8T
Voltage: 6S~10S Lipoly
RPM/V: 1100kv
Motor Poles: 8
Internal resistance: 0.0083 Ohm
Max Loading: 105A
Max Power: 3880W
Shaft Diameter: 6mm
Shaft Length: 21mm
Screw Mounting Spacing: 25mm/30mm (M4)
Weight: 376g
ESC : YEP 120 LV (12 amper HV BEC içerir)
Specs:
Max Cont Current: 120A
Max Burst Current: 135A for 10 Seconds
Input Voltage: 2-6 cells li-XX or 6-16 Ni-MH/Ni-Cd Battery
BEC: 5.7v - 7.4v - 8.0v/12A Selectable BEC
PWM: 8~16 KHz
Max RPM: 240,000rpm for 2 Poles Brushless Motor
PCB Size: 66 x 32.5 x 25.7mm
Weight: 100g (including wires)
Hitec HV Cyclic servolar:
Performance Specifications
Operating Voltage Range (Volts DC) 6.0V ~ 7.4V
Speed (Second @ 60°) 0.16 ~ 0.14
Maximum Torque Range oz. / in. 122 ~ 139
Maximum Torque Range kg. / cm. 8.8 ~ 10.0
Current Draw at Idle 7 mA
Stall Current Draw 2,600 mA
Dead Band Width 4 µs
Kuyruk HV Servo:
Operating Voltage: 6.0~7.4V~8.4V
Operating speed: 0.06sec 60°@ 6V~0.05sec 60°@ 7.4V~0.04sec 60°@ 8.4V
Stall Torque: 12kg @ 6V~15kg @ 7.4v~18kg @ 8.4V
Working Frequency: 1520µs/333hz
Weight: 70g
Dead Band: =2uSec
Motor: Brushless
Ball Bearing: 2BB
Gear Train: Metal
Fiyat: 2500 TL
Modelin konusu
Turns: 8T
RPM/V: 1100kv
Motor Poles: 8
Max Loading: 105A
Max Power: 3880W
Shaft Diameter: 6mm
Shaft Length: 21mm
Weight: 376g
Specs:
PWM: 8~16 KHz
Kuyruk HV Servo:
Weight: 70g
Dead Band: =2uSec
Motor: Brushless
Ball Bearing: 2BB
Gear Train: Metal
Fiyat: 2500 TL
Modelin konusu
