[Satılık]: Elektronikler ( Esc, Gyro, Pil, Servo, Motor)
Durum
madmanx
Uye
25 Eyl 2013
elimden geldiği kadar detayları vermeye çalıştım, daha detaylı bilgi isteyenler isimlere göre nette arama yaparak satış sitelerinde bilgi edinebilirler. malzemelerin hepsi sıfırdır, fiyatlar tane fiyatıdır.
Emax CF2805 motor 2840 kv 25 TL
KV: 2840
Motor Weight: 27g
Number Of Cells: 2S LiPo
Current: constant current: 12A-max current: 14A (for 30 Seconds)
Motor Diameter: 28mm
Total Length: 37mm
Shaft Length: 11mm
Shaft diameter: 3mm
Recommended Model Weight: 200g-300g
Recommended Propeller: APC 7x4 -APC 6X4
sunnysky X2204S 2300 kv CCW motor 40 TL
Height: 28mm (to top of shaft)
Width: 27mm
Weight: 21g
Battery (Cell Lipo): 2-3S
KV: 2300
Turnigy 1811 3800 kv motor 30 TL
Dimension: 22mm x 18mm, 30mm(with shaft)
Weight: 11g (kv2300) (not including connectors)
Diameter of shaft:2mm
Length of front shaft:8mm
Lamination thickness: .2mm
Magnet type: 45SH
Wing Wing Z-84 2900KV Brushless Motor w/Prop Adapter 30 TL
RPM/Volt: 2900KV
Voltage: 7.4V
Weight: 23g
Savox SW-0250MG Waterproof Digital Metal Gear Micro Servo ... 80 TL
Dimensions: 29.5x14x32.5mm
Weight: 25g
Speed @6.0V: 0.11 sec/60
Torque @6.0V: 69.4 oz-in (5.0 kg-cm)
Gear: Metal
Bearing: 2BB
Case: Plastic
Tooth Spline: 21
Walkera Master CP RC Helicopter Spare Parts Metal Servo WK-7.6-9 ... 30 TL ( 4 adet var )
Item Name: Metal Servo WK-7.6-9
Item NO.: HM-Master CP-Z-28
Brand: Walkera
Usage: For Walkera Master CP RC Helicopter
Diatone DIY FPV 250 quadcopter frame 30 TL
ilanlar, yukarıda yazan fiyatlar üzerinden %25 indirimli olarak günceldir, 100 tl üzeri ücretsiz kargo...
Durum
