Merhabalar arkadaslar.diger forumlardan kopyaladigim ve bazi degisiklik yaptigim listeyi olusturdum.inshallah gelecekde fpv ekipmanida dusunuyorum uzerine.listedekiler eski model ola bilir rica ediyorum bi bakardiniz ve yenilemek icin yardim ederdiniz.ve listede ne lazimsiz onuda soyleseydiniz sevinirdim.Yardiminiza cok ihtiyacim var.quad sektorunde yeniyim.fikrim biraz sportif birazda stabil video record yapmak ve gelecek icin fpv sistem olusturmak.2D Gimbal bagliycam bide fpv set olarak "Quanum Complete FPV Bundle Set w/ Goggles, 5.8GHz 32ch Video TX & RX, CP Antennas and Camera (PNF)" dusunuyorum.ama simdilik degil.kargo ucreti az olan site bilen varsa coook rica ediyorum link vererdiniz.Onceden Tesekkurler RCKOLIK ailesi
Dead Cat Conversion Kit for SK450 Quadcopter Frame 18.99
6pcs universal Tall Landing gear skid for DJI F450 F550 SK480 FPV aerial photo F 5.00
Original Sunnysky V2216 800KV Outrunner Brushless Motor x4 23.60
10x 3.5mm Gold Bullet Banana Connector Plug For ESC Battery Motor 2.60
Afro ESC 30Amp Multi-rotor Motor Speed Controller (SimonK Firmware) x4 14.00
TURNIGY 3A UBEC w/ Noise Reduction 4.76
8045 SF Props 2pc CW 2 pc CCW Rotation (Green) x2 2.79
Hobbyking KK2.1.5 Multi-rotor LCD Flight Control Board With 6050MPU And Atmel 644PA 21.99
M3 Nylon Nut (10pcs/bag) 0.69
5.6mm x 12mm M3 Nylon Threaded Spacer 0.86
Lion Power 11.1V 4200mAh 30C LiPo Battery BG703 x2 34.99
14AWG (1M Red + 1M Black) 2.66
Nylon XT60 Connectors Male/Female (5 pairs) GENUINE 3.29
Nylon_T_Connectors_10_Pairs_20pc 3.77
10CM Male to Male Servo Lead (JR) 26AWG (10pcs/set) 4.75
10CM Servo Lead Extention (JR) 26AWG(10pcs/bag) 2.53
ATG A-1 Propeller Balancer Magnetic 6.60
KUMANDA SETİ : 1 x Flysky FS-TH9X --var
ŞARJ CİHAZI : 1 x SkyRC iMAX B6 var
USBasp AVR Programming Device for ATMEL proccessors 4.46
1-meter-heat-shrinkable-tube-20mm 2.88
HK F-30A 9.99
Turnigy_Heat_Shrink_Tube_20mm_Transparent_1mtr 0.64
Turnigy USB linker 6.89
0.77Lion Power 11.1V 4200mAh 30C LiPo Battery BG703 x2 34.99
HK F-30A 9.99
