Spirit Firmware Yeni Sürümü : V 2.4.0 ESC Telemetri
Daha önce Spirit de ESC Telemetri özelliğinin geleceğini aşağıdaki konuda paylaşmıştık. Çok beklemeye gerek kalmadan 01 Mayıs tarihi itibari ile yayınlanan "Firmware V 2.4.0" ile bu özellik gelmiş durumda :thumbup:
Spirit ESC Telemetri Özelliği - V2.4 Geliyor :
Firmware INDIRMEK için :
Bu yeni Firmware ile gelen ana özellikler:
1- μSpirit ünite desteği
2- ESC Telemetri desteği
** Tüm üniteler: μSpirit, Spirit, Spirit Pro
** Destekleyen Kumandalar: JETI Duplex, FrSky/OpenTX, Graupner HoTT
** Destekleyen ESC'ler : Castle Creations Talon, Phoenix and Edge, HobbyWing Platinum V4, Scorpion Tribunus ve Kontronik Kosmik and Jive Pro
** Izlenebilen Parametreler : Voltaj, Akım, Sıcaklık, Kapasite ve BEC Voltaj bilgileri (RPM bilgisi V2.3 itibari ile okunabiliyor)
Güncelleme Detayları
--Support for μSpirit unit:
Full support of the micro Spirit.
Compatible with all peripherals.
Can be used on helicopters of 130 - 250 size.
Support for ESC/Motor driven rudder.
New parameter Rudder - Control type to allow selection of the rudder drive.
NOTE: Will be supported by Spirit Aero firmware.
IMPORTANT: Older firmwares are not supported!
--Graupner HoTT integration:
ESC Telemetry support.
USB interface can be connected without repowering the unit - once integration cable is plugged off, the status led will be turned off and you can plug in the USB interface.
Small speed optimization of the integration.
Support for μSpirit.
--OpenTX Integration:
Significantly faster telemetry data refresh rate.
--JETI Duplex Integration:
Telemetry data rate was optimized.
Support for Servo reverse CH0 for CCPM 90 swashplate.
Support for Subtrim CH0 for CCPM 90 swashplate.
--In-Flight Vibration Analysis:
FIX: Can be used with F: Stabi function.
Can be activated all the time with no downside effect.
--ESC Telemetry:
Support for telemetry data from the ESC - all data can be displayed directly in your radio.
Available for JETI Duplex, FrSky/OpenTX, Graupner HoTT.
New Telem CC, Telem UNI and Telem KONTRONIK telemetry cables.
**Castle Creations Phoenix and Edge:
Battery Voltage
Battery Current (experimental)
BEC Voltage
Consumed Capacity (experimental)
ESC Temperature
HobbyWing Platinum V4:
Battery Voltage
ESC Temperature
**Scorpion Tribunus:
Battery Voltage
Battery Current
BEC Voltage
Consumed Capacity
ESC Temperature
**Kontronik Kosmik and Jive Pro:
Battery Voltage
Battery Current
BEC Voltage
Consumed Capacity
ESC Temperature
NOTE: All telemetry guides are available at the Wiki pages.
--Wifi-Link module:
Support for the latest 2.4 firmware.
Support for the ESC Telemetry.
Support for the μSpirit.
Improved detection of the firmware version with more clear messages.
--Spirit Settings - Android:
--Spirit Settings - FreeBSD:
Launch scripts for better architecture detection updated.
Stability was enhanced.
--Improved Setup Wizard:
New schemes with μSpirit.
Improved detection of the unit swapping..
New Profiles: T-Rex 150, T-Rex 250, Oxy 2, Blade 130S, Blade 180CFX, Blade 230S.
--Governor:
Sensor Activity analyser was improved to work with all governor sensors.
Güncelleme Detayları- TURKCE
YAKINDA ÇEVRILECEK :)
Bu arada yeni gelişmeler sipirit de devam ediyor hafta ici spektrum kumandalar için entegrasyon guncellemesi yayınlanacakmis.
Mustafa Çoban.' Alıntı:
Beklenen hareketler bunlar :bravo: :yuppi:
Güzel bir haber, paylaşım için teşekkürler Mustafa. :thumbup:
